tjschramke's avatar
tjschramke
Nighthawk RAX120V2 DROPPING SPEEDS TO 100
Nighthawk RAX120V2 DROPPING SPEEDS TO 100 - Any solutions to this... I have rebooted multiple times - changed out cables... please help. Thank you
  • FURRYe38's avatar
    Happening over wireless and wired?
    What devices are connected?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How is the RAX120 configured and connected to the ISP service device? Yellow WAN port or the Multi Gig port?
    • tjschramke's avatar
      tjschramke
      Happening over wireless and wired?  BOTH
      What devices are connected?  wifi devices are cameras, laptops 2x, desktop, Frig, 2 gaming consoles, phones...
      What Firmware version is currently loaded? The current version V1.2.9.52
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? using only netgear and plugged into the wall...
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. I will have to check - how?
      How is the RAX120 configured and connected to the ISP service device? Yellow WAN port or the Multi Gig port?  Yellow Wan port. and then 2 other ethernet going up stairs for wired connections.
