uwdj75's avatar
uwdj75
Follower
May 21, 2022
Nighthawk RAX45 - Where is the Transmit Power Control after latest firmware update?
My Nighthawk RAX45 router is updated to firmware version V1.0.11.112_2.0.77.
I cannot find the Transmit Power Control anywhere. Did Netgear remove that option from the firmware? (It used to be on the Wireless Settings page.)
While watching TV I normally sit about 2 feet from the router, so I would set the Transmit Power to 25%.
  • Transmit power is fixed as per FCC demands. I guess that's why NG removed it. To comply.
    • tallpeak's avatar
      tallpeak
      Then the UI should show the current setting, 25% (where I left it) or 100% (if forced to that new value by the firmware update), grayed-out to indicate that I cannot change the transmit power anymore. Removing the functionality while hiding the fact that it was removed was confusing! (Is it at 25% now, where I left it? I'm only getting 2 out of 5 bars, 30 feet away...and it works okay I guess, but I lose packets sometimes; it might work better at 50%, or do I need to move the router closer?)
      • FURRYe38's avatar
        More then likely the power is at 100% after you did the FW update. To ensure this, do a factory reset and setup from scratch. The UI should read 100% or grayed out or no longer appearing in the UI.
