Mike005
Dec 29, 2018Aspirant
Nighthawk RAX80 5G Radio problems / intermittent
I've purchased 2 RAX80 routers and both have problems with the 5ghz radio. The signal is intermittent, showing and disappearing, one router is worse than the other. I've performed extensive troublesho...
dmystic1
Dec 29, 2018Apprentice
Are you using DFS Channels? Some devices won't see them.
Mike005
Yes and no, I've tested with and without. Same problem.
- Richard1864Dec 29, 2018LuminaryYes, with DFS channels. All our devices, except for IoT, are Apple and work fine on 5GHz with no issues. The others all play nice on the 2.4 GHz. I assume you’ve got the latest firmware on the router; drivers for Intel and other Wi-Fi chipsets (for Windows) are only available from their respective vendors, not Windows Update. You’ve checked on those vendor sites you’ve got the latest drivers? Intel released updated drivers in late November and early December that make their chipsets compatible with the new WiFi 6 routers. Chipsets more than 2 years old won’t work with these new routers and will behave as if the 5 GHz isn’t working properly, just like you’re describing.
