tijsco
Feb 15, 2021Guide
Nighthawk RAX80 very unstable - losing connections
Hi all, I've bought the RAX80 six weeks ago and it's been very unstable since then: - devices losing wifi connections - devices not seeing the wifi network - RAX80 losing internet connection (...
GabboCH
Mar 07, 2021Apprentice
If you read the forums this is a common problem with the RAX80 with no solution (or acknowledgement from Netgear) that its a problem.
My RAX80 cannot maintain Wifi connections, constantly resets LAN connections & requires a reset every week.
These problems were reported more than 18months ago by many users without any attempt to correct these problem from Netgear.
I placed another Wifi5 router from Netgear in the exact same location (same settings, SSID, SmartConnect ON etc) and this works without any issues.
The only solution most people seem to have found is to return the RAX80 & buy something else.
You wont get any support from Netgear for this problem except "your service contract has expired, would you like to buy our extended telephone support so that we can help you?"
This is 2020, "corrupt" firmware after flashing is not a problem.
If a router cannot detect bad flashing itself it is not worth €250..!
mabato
Mar 08, 2021Aspirant
Dealing with the same issues after getting it replaced twice. Paid their support team for a $80 6 month extended tech plan and their solution for me is to buy a new router and junk this $400 router. Can we start a class action suit on this? 🤦🏻‍♂️
- plemansMar 08, 2021Guru - Experienced User
Might want to read the Terms of service.
NETGEAR Community Terms Of Service | Answer | NETGEAR Support
- Off-Topic posting
- Thread hi-jacking
- Spamming
- Cursing or other profanity
- Ranting
- Discussion or suggestions involving illegal activities
- Private or personal information (e.g. posting of NETGEAR customer service agents’, NETGEAR employees’, or other Community users’ names, addresses, email addresses, or telephone numbers)
- Linking or posting of pornographic material
- Linking or posting of advertising, promotions, or contest materials that are not provided by NETGEAR
- Threats of legal action against NETGEAR or other parties
