Matthewlawson3's avatar
Jun 06, 2024
Nighthawk RAXE500 - Checking speed and for Firmware Problems
Hi, I have the Nighthawk RAXE500 and recently began having problems with my Simplisafe cameras. So I thought it is probably a Simplisafe issue. But when I ran a Speedtest at Speedtest.net I noticed my 2.4 GHZ is not exceeding 150mbps while my 5 GHZ is hitting 906mbps on my gigabit connection.
I'm trying to determine if 150mbps is normal for that router on 2.4 GHZ or if something has changed (maybe bad update) and slowed the 2.4 band down. I'm running the latest firmware on the router at version 1.2.13.100.
Can someone help me out?
  • michaelkenward's avatar
    michaelkenward
    That's a pretty good speed for 2.4 GHz. It all depends on the wifi clients you are using. Cameras don't need that speed to do their stuff.
    You don't say what the problems are, but speed is unlikely to be the issue.
    ...my 5 GHZ is hitting 906mbps on my gigabit connection.
    That is suspiciously high. More like a wired speed than anything most wifi clients can use.
    What "firmware problems" do you have?
    • Matthewlawson3's avatar
      Matthewlawson3
      Tutor
      Yes sorry the 900 area Mbps would be over my Ethernet.
      I'm not having any firmware problems as far as I know. I was trying to determine if my 2.4 GHZ was slower because of a firmware issue. But if you are saying the speeds are in the right ballpark I guess it is not that.
  • plemans's avatar
    Like everyone is saying, you're hitting the speeds we'd expect out of 2.4ghz. the "up to speeds" are way overblown and 2.4ghz is atrocious on speeds. But it reaches further and through more things.
    Were you simplisafe cameras fine before?
    Do they connect back to a hub?
    How many devices are on 2.4ghz?
    Have you tried changing 2.4ghz channels? Maybe someone is broadcasting interference in your area.
    How far apart/distant from the router are they?
    Are any of them 5ghz capable that you could switch them over to? 5ghz is less sensitive to interference than 2.4ghz .
    • The cameras were fine and suddenly started acting up. Some of my cameras connect to a repeater on one side of the house, which pushes my main Netgear Nighthawk router's WiFi out to those cameras and some cameras connect to the main router. It's been this way for a year and been fine. All the cameras seem to be having this issue.
      I did change channels on the main Netgear router yesterday. It didn't fix the issue. unfortunately.
      I have several devices on 2.4 but most are not on and I've been running this way for a year with no problem.
      None of the Simplisafe cameras can do 5 GHZ unfortunately.
      • plemans's avatar
        What repeater do you have? Must wireless extenders drop throughout by over 50% by the very nature of how they work
