Ray65
Jun 21, 2022Aspirant
Nighthawk Router RAXE500
I am confused about the Wi-Fi settings in my Router RAXE500
I enabled
AX
2.4Ghz
5GHz
6GHz
and smart switch is disabled
The 2.4GHz and the 5GHz have the same password the SSID names are slightly different
but my 6GHz has a completely different password
My Samsung galaxy S10 when it logs onto the Wi-Fi it showing it logged on to 6GHz
but I'm not using the 6 GHz password
so I am confused on how all this works
and just to add. I don't broadcast my SSID
What happens if you change the PW on the 2.4 and 5Ghz SSIDs to something new and don't use those. Does the phone still connect to the 6Ghz radio?
Had you used the 6Ghz PW prior any?
The S10 doesn't have a 6ghz radio.
You might be mixing up Wifi 6 with 6ghz.
6ghz is a hardware difference and the S10 won't even be able to see 6ghz.
https://www.howtogeek.com/519823/wi-fi-6e-what-is-it-and-how-is-it-different-from-wi-fi-6/
https://kb.netgear.com/000062799/What-is-the-difference-between-WiFi-6-and-WiFi-6E
- Ray65Aspirant
All Samsung galaxy S10 are capable of handling 6G
with all the recent new updates
https://www.theverge.com/2019/2/20/18232366/samsung-galaxy-s10-wifi-6-lte-speed#:~:text=All%20three%20new%20phones%2C%20the,or%20just%20your%20home%20router.
With that said, if I disable AX
the Wi-Fi signal does not display the number 6 anymore which indicates 6 GHz
so that is verified
what is not verified. If 2.4 GHz and 5 GHz have the same password
how is it that my phone is picking up 6 GHz.
When the 6 GHz has a completely different password.
And I'm not using that password- plemansGuru - Experienced User
Incorrect. Read the article you linked to. The S10 is wifi 6. Not 6E. 6E includes the 6ghz spectrum.
wifi 6 is simply wireless AX which is 2.4ghz and 5ghz. The 6E adds in 6ghz.
The S10 does not have any 6ghz capability.
Wifi 6 does not equal 6ghz.
