dchadduck's avatar
dchadduck
NighthawkRAX54 not connecting after only 3 months. ???? What now??? Thanks
Tried different ports. No connection.
Modem to computer works fine.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • dchadduck's avatar
      dchadduck
      Don't know how to access Router from computer. It's on 5 Ghz for wifi pre led light.
  • michaelkenward's avatar
    michaelkenward
    Not connecting to what? The Internet? Wifi not working?
    What do the LEDs on the router look like?
  • plemans's avatar
    You didn't really give us much to go off.
    Everyone has pretty valid questions that seek more clarity.
    The more you tell us, the better we can help you.
    1. what firmware is on it?
    2. what modem/gateway is it connected to?
    3. what do you mean it won't connect? Won't connect to the modem? Devices won't connect to the wifi? Will connect to the wifi but don't have an internet connection? Won't connect to wired devices?
    Details are key in helping out on online forums. So go into depth.
    You also put that its only 3 months old. Netgear does have 90 days of free support. If you're within that 90 days, you could contact support for free for help.
      dchadduck
      Firmware is current I believe. Not sure how to verify.
      Router is Netgear CM700
      Router does not connect to the internet nor does wifi work.
      Open Chrome and click on bookmarked site and I get the message "Your connection is not private" and "NET::ERR_CERT_AUTHORITY_INVALID". message.
      Open Edge and click on bookmarked site and I get a default Netgear screen that says I should download the Nighthawk install app. I got a flip phone so that won't work.
      No other computers or devices attached.
      • FURRYe38's avatar
        The CM is a modem only, no router here.
        Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
        Turn off and unplug modem.
        Turn on computers and rest of network.
