sammybk
Mar 14, 2023Aspirant
No 5ghz SSID when setting 160mhz channel - RAX50v2
Just opened the box and setup RAX50v2 with Firmware Version V1.1.3.18_2.1.14.
On setup no 5Ghz wifi was showing up. I changed the channel size down to 80mhz and it works like a charm. Back to 160mhz, no 5Ghz SSID.
Is this the expected behavior if I'm near radar (I live right near an airport in the USA), or is the router defective?
- microchip8MasterMost likely a radar issue. The router constantly scans for it when using a DFS channel
Try changing the channel to the lower 5ghz channels when you have it set to 160hz. See if that helps.
Are you using smart connect.
