texaggie1994
Jan 28, 2023Aspirant
Orbi With Nighthawk AX6
I have Orbi RBR40 with 3 satellites installed and if works wonderfully, except for inside my metal shop building. The satellite is mounted on the wall outside of the building, but inside the signal is blocked. I bought a Nighthawk RAX49 AX6 to "extend" the signal inside the building by running an ethernet cord from outside plugged into the ORBI satellite, and then plugged the other end into the AX6 inside the building. The internet connection light is always RED.
What can I do to correct this? I've heard it needs to be "bridged"?? Help Please
What is the model# of the AX6? EAX##?
- texaggie1994Aspirant
RAX49
Try putting the RAX in AP mode:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
