wendyjm
Oct 19, 2021Aspirant
Port Forwarding Not Working
I have a Netgear CM1200 modem and a Netgear Nighthawk RAX80 router. We use Xfinity for our ISP. I have a minecraft server set up with a static IP that works properly when on the same network. I have setup port forwarding for the server on the router but it can't be seen off the local network. Canyouseeme.org is showing the external IP address but says the port is blocked. What else can I do? The server is showing up in the table as a custom service. OS: Ubuntu
