akhan999
Jan 02, 2024Aspirant
Port forwarding settings disappear RAXE500
I noticed by PBX server was no longer visible outside of my home network. Looking further into I noticed Port Forwarding / Port Triggering settings were no longer visible in the Netgear UI. I restarted the server and they reappeared. Only to disappear again the next day. This seems like a BUG and I see similar issue on other routers, sounds like something Netgear can't figure out?
It's a big problem for me as I can't use my PBX system outside my home.
Anyone got a solution here?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Is uPnP disabled while the PF configuration is enabled?
Try the PBX service device in the DMZ on the RAX instead of using PF configuration?
