blackcoyote13
Dec 29, 2018Follower
QoS bandwidth limiter not working on Netgear RAX80
I just got my new RAX80 installed and setup and all is working well so far. However, even when I enable Dynamic QoS and enter manual bandwidth (vs speed testing), the bandwidth is not limited to what...
myersw
Jan 02, 2019Master
Gosh what a surprise. QoS not working.
Doesn't work on current been out router either.
DarrenM is Netgear ever going to be able to supply firmware where the basics work?
myersw
Jan 02, 2019Master
What is your Internet speed? Maybe you do not need QoS.
- DarrenMJan 02, 2019Sr. NETGEAR Moderator
Have you tried to disable the QOS renable and then enter the value again?
DarrenM
- schumakuMar 12, 2019Guru - Experienced User
Not convinced the bandwidth you configure in the QoS settings - which is mainly used as a base for the QoS service allocations (some black magic) - is also supposed to act as a hard bandwidth limitation. Where have you read this is intended to work as a global bandwidth limitation?
We've seen a few users in the past who have tried to install multiple routers on the same Internet connection, and use this setting to adjust the available bandwidth - which came to the same conclusion.
