thehypnootoad
Feb 17, 2021Luminary
Rax 120 issue
Everytime i make a change on the router to do with wifi or internet the change bar does it but the internet stops working and can only be sorted by turning on and off again is this a bug running latest firmware done 10 second reset.
- No1MportntLuminary
Does it restart after the progress bar gets to the end? Sometimes it does take a few seconds after the progress bar gets to the end.
- thehypnootoadLuminaryI leave it till bar finishes then it times out I normally leave it upto 10 minutes all lights are on but no connection I manually reboot it.
What firmware version is it on?
What modem/gateway is it connected to?
- thehypnootoadLuminaryI believe its version Support
RAX120 Firmware Version 1.2.0.16
Modem is huawei hg612b unlocked to see stats- jweaver4475Aspirant
Which settings in the router are you changing?
Are you connected wirelessly or with a wired connection when making these changes?
