Link12345
May 30, 2020Initiate
RAX 200 not receiving IP from modem
Hi all, I have a Rax200 and it was running fine until last night. I restarted the modem cm1200, waited 2 minutes and did the same with the router. Logged in using 192.168.1.1 and couldn’t finish the ...
- May 30, 2020
I've got a similar setup. I've got the RAX200 and the CM1100.
power them both off and unplugg everything from both (including coax).
hook the coax back up to modem.
power the modem on and give it several minutes.
then connect the lan cord from port 1 on the cm1200 to the wan port on router. (don't use port aggregation)
power on the router. give it several minutes.
Then try setup. also during setup, ensure the wan port settings are set for using the wan port and not port aggregation or the multigig port.
May 30, 2020Guru - Experienced User
