t84a
Oct 04, 2023Aspirant
RAX-42 Port Based VLANs
This post is very similar to a post I made several years ago.
I'm trying to mitigate wifi congestion.
I want to assign 2 of the ports to 2 additional (separate) VLANs. I would run a couple Unifi APs to one of the VLAN ports for the Fire Stick based TVs. I would connect a camera NVR to the second VLAN.
Do I need to do anything else like tagging or are the physical connections sufficient?
That's not supported on this or any model NG home class router. Most VLAN and VLAN Tagging is kept to the Manage switch domain.
You might check out Orbi Pro and see if there is any VLAN support that your looking for there.
- t84aAspirantThanks. The manual references setting up bridge ports.
Maybe VLAN was the wrong term.- FURRYe38Guru - Experienced User
What page is that on?
I believe this model router only sports Router, AP and Wireless Bridge mode. Wireless bridge mode would let the LAN ports be used like a switch. Just no VLAN features here though. Just LAN ports for devices to connected to while in that mode.
