Alexcabrils's avatar
Alexcabrils
RAX blocking emails
My RAX 70 started blocking my email some weeks ago, its an intermitent issue, when is happening I can switch from the wifi to my phone hotspot and everything works normal but when I go bacj to wifi the mail is not receiving or sending emails and I have the disconected icon on the accounts. Any suggestion or solution? Thanks.
  • plemans's avatar
    Is it only happening on your phone? Or does it happen on pc/laptops?
    What device is it?
    If its an ios device, try disabling icloud relay and private mac/ip address.
    • Alexcabrils's avatar
      Alexcabrils
      Hello, is happening everywhere, iphone, 2 macs and ipads... everything connected with the router by wifi has de problem.
      • plemans's avatar
        What firmware is on the router?
        What modem/gateway is it connected to?
        are you using a vpn?
