11jar11's avatar
11jar11
RAX10 - I have a reset question.....
My router is connected to fiber.  Ziply to be exact.  I use the wifi for two laptops and a linux desktop.  The only other connection is my Roku.  I never changed anything regarding security.  First I would like to know if resetting the router will affect my Roku?  Secondly I would like to know what I should do to be safe.
I am not a communications person so try and keep the discussion to a low level.
Thanks a bunch
John
  • FURRYe38's avatar
    Is there a problem that you need to factory reset?
    Might give more details regarding if there is a problem.
    Might try a full power OFF of the router for 1 minute then back ON as a simple first step to check for something.
  • michaelkenward's avatar
    michaelkenward
    What makes you think that you are unsafe?
    Changing passwords is the only thing that can affect security.
    One password manages access to the browser graphical user interface (GUI).
    The default GUI password (password) is on the router.
    Then there are the wifi passwords:
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Specify Basic WiFi Settings.
    or
    How do I change the WiFi password or security level on my NETGEAR router? | Answer | NETGEAR Support
    Possibly. Don't do it unless you have to.
    You should check this though:
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
