darryl1020's avatar
darryl1020
RAX10 internet issues
Hi all,
My netgear is unable to connect to my optus NBN after I had a storm last night. I have confirmed NBN itself is working.
How can I address this please
Refer to the photos attached
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • michaelkenward's avatar
    michaelkenward
    How does NBN deliver the Internet to you? What modem/ONT/gateway? Is that still working?
    Storms are an excellent source of electrical spikes that can kill electronic kit. No amount of protection will protect your stuff from a short sharp voltage spike.
    Troubleshoot starting at the plug in the wall.
    Just another user with time on their hands.
    • darryl1020's avatar
      darryl1020
      Thanks everyone, I have decided to return my unit via warranty and get another unit as I dont want to pay AUD150 for technical support from Netgear
        michaelkenward
        Good luck there.
        Warranty support isn't likely to cover storm damage.
        Support here costs nothing, but you do have to provide a few more details and try some simple tests.
        You may have to go through those hoops to persuade Netgear to issue an RMA.
