robertoselmi
May 25, 2020Tutor
RAX120 + NIGHTHAWK® MESH WIFI 6
Is it possible to use a NIGHTHAWK® MESH WIFI 6 system connected to a RAX120 router to increase coverage? If it is, how?
- Christian_RNETGEAR Employee Retired
Hi robertoselmi,
Yes, you can connect the Nighthawk Mesh system to a RAX120. You will need to set the Nighthawk Mesh system to access point mode to accomplish this.
Christian
- In this way the RAX120 publishes the SSIDs and the two non-wired mesh objects republish the same SSIDs, if I move from one place to another I keep the connection because the SSID does not change and I roam transparently. Correct?
- Any response?
