Feb 20, 2020Guru - Experienced User
RAX120 Beta Firmware
If you've got a RAX120 and want to try out some beta firmware or are having issues and want to try the new beta firmware, private message Christian_R and Christian will give you access to the forum/firmware to try.
I'd recommend making a backup configuration prior to the upgrade in case there's issues.
Also try to upgrade over a hardwired line. I've had the best result with a factory reset and reinstall afterwards. not always needed but does tend to help if there's issues after the upgrade.
- TopologyVirtuoso
Plemans, can you kindly post the list of (a) New Features and Enhancements and (b) Bug Fixes included in the RAX120 beta firmware?
Thank you.- plemansGuru - Experienced User
You'll have to message christian for access and details. There's a non-disclosure with beta firmware. And then you can get the specific details on the beta post with the firmware. That's why you need to get approved. You don't have to install it should you choose not to.
- TopologyVirtuoso
Plemans, thank you for the prompt reply.
Just a guess, but I suspect that the new RAX120 firmware will include (among other enhancements) a fix for the security certificate issue (see Why am I getting a security warning when I try to log in to my Nighthawk router?)....
