SuperHero
Nov 01, 2020Tutor
RAX120 Disconnect
I Feel Very upset that . My RAX 120 Router was disconnect the internet in every 2-3 hrs .
I need to power off the power to resume opeartion ..
I had already update the new firmware but without any improvement .
If I change back to my old router , it work very fine and wihtout any disconnect issue .
I change different of DNS for try , still without any improve .
It should be the software issue in RAX120 .Why the router disconnect all the time . How to fix it ? Can someone to help me ?
What modem are you using?
what firmware is on the router?
After the firmware upgrade, did you factory reset and reinstall the router? The RAX devices responded favorably to such. Just don't reinstall using a backup if an old setting is causing the issue.
- My Modem is RAX120 and already update the new firmware. Version 1.0.2.136 I had already try to reset the modem to factory reset and setup the modem again (instead of using backup to reinstall) couple time . But still have same problem . The modem still disconnnect by themselves . Can you tell me how to solve ? CH
