thehypnootoad
Apr 25, 2021Luminary
RAX120 Is it ever going to be fixed
Ahh the famous RAX120 the expensive router I want to use but can't due to too many issues (already had rma tried most firmwares even switched provider and changed modems)
Unfortunately I would love to use this router instead of the d7000 but hey is there light at the tunnell.
What I want to know is there ever going to be fixes for this router?
Is there any beta firmware been worked on to try it out?
Thanks Ashley
Thanks Ashley
This is the netgear community forum. Its rare to find a moderator on here and they don't discuss upcoming firmware changes.
You're running the d7000 as a gateway?
Does the RAX120 have issues when its ran in access point mode and connected ot the d7000?
- thehypnootoadLuminaryWill give it a go I can also use the modem and run 120 in access point only problems is you don't get full functionality in access mode compared to router mode do you?
You do lose some functions in AP mode but the D7000 should be running those functions.
