springsnow's avatar
springsnow
RAX120 no 5GHz
5GHz isn't seen from any device. I've power cycled, flipped the radio on/off, and factory reset. I tried using smartconnect, but devices only listed as connnected to 2.4. I also tried no broadcast and entering the name into the device... no luck. The 5GHz activity light is on, but devices can only see the the 2.4 GHz. Am I stuck waiting for new firmware? I haven't disabled the AX option yet, that's what I'll try next. Any help is appreciated.
    Try different channel DFS and non DFS Channel also make sure Enable SSID Broadcast is active.
    • RAXHawaii's avatar
      RAXHawaii
      I have the same issue. I tried changing channels, reset the router, toggled AX mode on and off. Does anyone have a solution for this. As of now, all my devices are connecting to 2.4. My 5g light is active. It’s not broadcasting the -5G. And my smart connect is off.
      • springsnow's avatar
        springsnow
        I ended up having to RMA as support thought it was hardware related. Hopefully you are able to do so.
