thehypnootoad
Nov 15, 2022Luminary
Rax120
When I try change ipv6 dns either to goigles or cloudflares it works but all the web pages seem to load alot slower tried a web ipv6 tester says all is good any suggestions thanks Ashley.
How is the IPv6 configured on the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Are you using a wired or wireless connection?
Happens on all devices?
Might try a factory reset and setup from scratch. Leave debug page features disabled.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
- thehypnootoadLuminaryHi tried the turning off and on but still slow pages, the ipv6 is on pppoe but tried 6-4 and auto detect. Iam on the latest firmware on the rax 120v1 also been into debug page and allowed ping internal external ipv6.
