thehypnootoad
Jan 22, 2024Luminary
Rax120
Had new isp connected today so reset the router plugged the new fttp modem into the netgear router via ethernet and it just wont connect. Rang Quickline for the details but it just wont work. Used pppoe and rang back to check details are correct but the netgear rax will just not connect any help will be appreciated.
Do you have an ONT? If so, some require VLAN20 or VLAN21 being set on the router. Consult on that with your ISP.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Something to contact the ISP about for help and information regarding there services.
- thehypnootoadLuminaryDone all that thanks
- microchip8Master
