DrWatt
Aug 06, 2022Aspirant
RAX120v2 How to determine which device is connected to which of the numbered ethernet ports
RAX120v2
firmware version: V1.2.3.28
Windows 10 Pro version 21H2
Summary:
How to find what device is connected to ethernet port 1, what device is connected to ethernet port 2, what device is connected to ethernet port 3, what device is connected to ethernet port 4.
It won't tell you device specifics but it will show the connection details under the wan port statistics.
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
- DrWattAspirant
I was hoping that it would provide either the device name or MAC address (or both) attached to each ethernet port. I suppose I will just have to manually test each cable and then apply a label.
Many Thanks for your reply.
