alpnet17
Jun 05, 2021Initiate
RAX20 authentication problem
I have Netgear model # RAX20. My cell phone (Android) cannot connect to Netgear WiFi. I get this message: "Authentication Problem" . How can I connect my cell phone to Netgear WiFi?
did you put in the password wrong?
Try deleting the network from your phone and re-connecting it.
Didn't work for me.
Changed the password, same error
Made the network open, got "can't connect"
Then went back to password protected and went back to the error
Is it only 1 device with the issue?
Are you using any special characters in the ssid/password?
No
Tried that several times
siliconglen Maybe start your own thread so we can go over your info and not get it confused with the OP
- alpnet17Initiate
I tried your solution and it worked fine. Thank you.
