347Eric
Nov 29, 2019Aspirant
RAX20
My Nighthawk will see all of the devices in my home, tv's, cameras, phones and a personal laptop. My company sent a new laptop and for some reason the company laptop will not see the Nighthawk. The company laptop will see several "wifi" on my street. My company tech support says that the Nighthawk has blocked all new devices. That is not true because a friend of mine just came by and he connected his laptop and his phone and, my daughter was able to connect her phone to the Nighthawk approximately two weeks after the Nighthawk was installed.
Please help!
What wireless card is in the laptop?
Many of the newer laptops with the intel chipset need to be updated before they'll work with the RAX devices. I had this issue with an intel ax200 but as soon as I updated the driver from the manufacturer, it worked great. Don't trust the built-in driver update tools in some of the laptops. Actually look up the card and go to the manufacturers website to get the driver.
- GabboCHApprentice
What make/model is your laptop & what Wifi device does it use?
If it uses an Intel Wifi adpater it is likely you need to update your drivers to correctly work with the new AX Wifi functionality.
For my Intel NUC PC, the drivers offered by windows were "up-to-date" but didnt work (i could not see the SSID).
I downloaded the latest driver from the intel website & it worked fine after that.
I had to do the same thing for my 2 dell work laptops.
If it is not possible to update the drivers (as its a work laptop & you dont have admin rights) which was the case for my wifes Dell laptop, you can disable the AX functionality in the router as a last resort.
However, if you do this, you are loosing one of the main functions of Wifi6 so its best to try the driver update first.
- 347EricAspirant
GabboCH wrote:What make/model is your laptop & what Wifi device does it use?
