Unbreak_Able
Oct 12, 2022Aspirant
RAX200 - Extender IP addresses on devices page
Hi all,
I have a RAX200 that I got recently but need wifi to the driveway and garage. So using old asus router as range extender (repeater). The Asus as repeater mode will only show connected devices it gets from the main router (RAX200).
The RAX200 Attached Devices page will only show anything connected directly to it.
It will not show anything connected via the repeater (Asus).
I wonder why the Attached Devices page cannot list all the IP addresses it is allocating to the Asus repeater? It just gives the one address (not always the one belonging to the repeater itself either).
The old Voda router would display every device in it's own right (even those attached via repeater/extender).
Unclear why RAX200 needs to be sub-par vs a free ISP router.
Anyone think I'm wrong or have a better suggestion?
Cheers
Cheers
- Something I should probably have mentioned ; I spoke to NG support earlier and they confirmed that the router will only show one IP per attached device and it will only show devices connected directly to the router (will not show devices connected to the repeater/extender).
Possibly that the ASUS maybe masking devices that connects to it and is not passing thru to the RAX.
Something to ask ASUS about.
- Unbreak_AbleAspirantI've run the asus as repeater for the old Vodafone isp router and it was passing them through to that fine. So I don't think it is the Asus router.
Try a NG branded extender/repeater to check that.
I could be the asus in extender mode is using its own IP address range to assign to devices.
have you checked that?
- Unbreak_AbleAspirantThe Asus doesn't have any IP address range in repeater mode. All that gets disabled when you put it in repeater mode.
Besides, the Asus addresses have always been traditional (192.168.1.*) whereas the RAX200 changed them to bespoke so as not to clash with the Vodafone router (which I have to keep as ISP gateway for FTTP).
- Unbreak_AbleAspirantSomething I should probably have mentioned ; I spoke to NG support earlier and they confirmed that the router will only show one IP per attached device and it will only show devices connected directly to the router (will not show devices connected to the repeater/extender).
