wanijsena
Apr 10, 2023Follower
RAX200 - WiFi 5ghz-2 disappears when setting 4800mbps
Hello, setting up my new RAX200 i noticed that 5GHz-1 is set to 4800mbps and 5GHz-2 is only set to 2400mbps.
I upped the second channel to 4800mbps and it has disappeared completely? WiFi analyzer no longer shows it. Is this normal? I tried setting 5GHz-1 to 2400mbps thinking only one could be set to 4800mbps but 5GHz-2 is still not there, only setting it back to 2400mbps seems to bring it back? Normal? Cheers.
what region are you in?
are you in an area with DFS?
What firmware is on the router?
- KitsapMaster
wanijsena wrote:Hello, setting up my new RAX200 i noticed that 5GHz-1 is set to 4800mbps and 5GHz-2 is only set to 2400mbps.
Educational material located here: https://www.duckware.com/tech/wifi-in-the-us.html#tribandhype
See appendix N
