trialcritic's avatar
May 06, 2021
RAX200 download speed slow
I moved from an X10 router to a new RAX200. I have a 1150v modem.
When I had the X10, I got a speed of 935 mbps.
My ISP plan has a download speed of 1200 mbps.
After the setup to RAX200, I get 710 mbps :(
My settings are:
  • Enabled AX
  • Enabled OFDMA in all bands
  • Disabled Smart Connect
  • Disabled 20/40 MHz coexistence
  • WPA2/PSK security in all bands
  • Disabled QoS
  • No link aggregation from modem to router
Any thoughts on how to fix this? Thanks
  • plemans's avatar
    How are you testing speeds?
    What website and device?
    Testing wired? Wireless?
    Many site struggle with speeds >500mbps and will give unreliable results.
    • trialcritic's avatar
      trialcritic
      Guide
      I tested with
      • wired connection of my laptop to the router, with using Ookla speedtest and Xfinity speedtest
      • using the Nighthawk app from my phone
      I did the tests over 10 times at different times of the day.
      Please note that the same sites had worked with my older X10 router
      • plemans's avatar
        When you're plugged directly into the cm1150v, what speeds do you get currently?
