Cabledogs420
Jan 04, 2021Guide
Rax200 gaming help
So I recently bought a rax200 to hook up four gaming consoles. I have fiber to the house from my isp. I have also gotten a static ip which got rid of double nat type. Consoles lan in. And have reserve...
schumaku
Jan 26, 2021Guru - Experienced User
axtriom wrote:I put nat filtering to open, Enabled UPNP same issues. I port forward but obviously only one device at a time can use the ports so thats no help.
No matter how hard you try - with one public IP address, one (WAN, Internet side) port can ony be forwarded to one LAN IP address. no matter which router you are using.
One of the ubiquitous ones is port 3075/UDP (Int. port) and different LAN IPs. What happens if using UPnP is that the second, third, fourth, .... console will see 3075/UDP is already occupied. The game will instead capture a different port on the WAN/Internet side (Ext. Port), and let the gaming server or game host in the cloud know about it.
Leaving the potential double NAT case alone (compare the WAN/Internet port assigned IP address with the "google what is my IP address"; ensure there is no ther NAT router; or the ISP does not do any CGN [Carrier Grade NAT]; or worse the low cost internet provider does even assign private IP addresses): remove any static pot forwarding on this port or the ports in question. Reboot router and consoles, and restart the games. If this does not work as shown in this example, there might be something wrong with the RAX200 UPnP PMP (port mapping protocol) feature.
This should allow a connection to 3075/UDP or 3151/UDP from many different addresses and gamers (that's what Open NAT makes up). If it would allow a connection from only one IP address at a time (that's stated to be moderate NAT then), again something would be wrong.
Note: The above example isn't made on a RAX200.
axtriom wrote:I am going through the same thing and youd think their top of the line model would be able to offer such simple requests. I can only get one console at a time to have OPEN NAT every other one will be moderate.
Can't agree more - this must work with all Open NAT and the RAX200.
Cabledogs420
Jan 26, 2021Guide
Well then something must be wrong for me. I have the static ip from isp so I don’t have double nat. As my carrier does have cgnat. But what is crazy is they will share etc for say twenty minutes and then poof. One system is on port 9038 another is 55232 where I have no idea that comes from. A lot of my issues I’m guessing stem from my carrier not having ipv6. It is driving me nuts cause on my r7000 or 8000 not sure which. Worked great for most everything except we kept losing the wifi networks and had to do hard reboot everyday. Gaming though all consoles were open and rocking. Thought ok we have streaming services now, gaming 1gb of speed I’ll go big maybe a little future proofing. Now I should say streaming movies homework and work for the wife as far those go are great. Gaming no way. I can’t even get my qos to work I go in change my console to highest hit apply. And just go back to where it was before normal etc. My brother in law let me borrow a asus one over the weekend everything fired up and all system open no echos from mics no lost network feature middle thru a game. So now I sit here and contemplate do I wait for the asus rapture gt axe-11000. Try the new one coming from Netgear in March. As I’m sure there is def something going crazy in mine. You call support for 90 days support I call bs they can give 1 year free support the fact they choose not to shows me they have to faith in hardware or software. As I can tell by many post of people and firmware issues.
- schumakuJan 26, 2021Guru - Experienced User
Cabledogs420 wrote:
Well then something must be wrong for me.Yes, I had the RAX200 UPnP PMP part in mind, indeed.
Cabledogs420 wrote:
One system is on port 9038 another is 55232 where I have no idea that comes from.Whatever you want to explain with these two numbers. Can't follow you.
Cabledogs420 wrote:
As I’m sure there is def something going crazy in mine. You call support for 90 days support I call bs they can give 1 year free support the fact they choose not to shows me they have to faith in hardware or software. As I can tell by many post of people and firmware issues.Netgear could save a lot of unnecessary support tickets by massively enhance and fix the many firmware issues - within reasonable time.
- Cabledogs420Jan 26, 2021GuideApologize in the upnp map each device shows what port it is using the devices will show 3074 on all devices. Go to devices they show open. Play 20 minutes go back to upnp and ports have changed for the devices. One says 9074 one will say 9028 and so on. And at that point a lot of network features have disappeared and we have to reset the console and everything starts to work fine. For a while then goes back. I thought console but happens on all of them. I appreciate your replies.
That's an interesting observation, great! Are the consoles wired, using wireless, or some mixed connection configs? Does this probably go along with a short connection loss and a disconnection as per the logs (if available)? This could be eg. also an short disconnect on the Internet side, a DHCP renewal, ...
Still convinced we see something between an oddity and a bug of the UPnP PMP implementation on the RAX200 here. Not sure about the best way to get Netgear's consumer BU for once to listen to us...
