Cabledogs420
Jan 04, 2021Guide
Rax200 gaming help
So I recently bought a rax200 to hook up four gaming consoles. I have fiber to the house from my isp. I have also gotten a static ip which got rid of double nat type. Consoles lan in. And have reserve...
schumaku
Mar 24, 2021Guru - Experienced User
D-MEAD wrote:
Did you ever get this problem fixed? If not and still want a option, you are going to need a different Router. The Netgear Nighthawk R7000, or the R7000P Both work right out of the box for this. Enable UPnP and in the router settings set Nat type to open.
This would create the NAT table as shown as above in my reply one might guess -> https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Rax200-gaming-help/m-p/2045951/highlight/true#M16663
D-MEAD wrote:
Problem will be solved. I haven't found a WiFi 6 option from any router company yet that can get this done.
Completely strange, considering there were at leas three different chipset makers with different dev kits.
What I wanted to ask - D-MEAD Fk-9?
D-MEAD
Mar 24, 2021Tutor
I don't know what you are asking. But the Netgear Nighthawk R7000 I bought in 2013 could do it. It died late last year. Tried most New WiFi 6 devices and couldn't find a solution. Bought a Netgear Nighthawk R7000p and right out of the box I've been able to get open Nat Type on 4 consoles. A Xbox One, 2PS4s and a PS5. No problems at all.
