Cabledogs420
Jan 04, 2021Guide
Rax200 gaming help
So I recently bought a rax200 to hook up four gaming consoles. I have fiber to the house from my isp. I have also gotten a static ip which got rid of double nat type. Consoles lan in. And have reserve...
TAS360
Jun 16, 2021Aspirant
Has this issue been resolved?
I am looking at buying the RAX200 but I have 3 Xbox's in my home and want to know that I will have no issues getting an open NAT on all consoles.
I currently have the R7000 and have not had any issues gaming with an open NAT on all 3 consoles all the time. If the RAX200 is unable to do this then I definitely would have to look at a different device to upgrade to.
Any help would be appreciated.
Cabledogs420
Jun 16, 2021Guide
As stated above they definitely can’t figure out how to fix it. If ur 7000 is working good just leave it alone. However if ur having issues or looking for better speed. I would order one from Amazon and maybe the asus model try them both see which works better and return the other one. I ended up with raxe500 as trial and was allowed to keep it. This seems to be working better for gaming but honestly the 6ghz network is a joke and my wife ran better with the high and low 5mhz so there seems to be to many trade offs so honestly gonna be trial by error for most people. Just said how far Netgear has fallen they were def on right direction with 7000 7500 but has since went backwards in my opinion. I wish I could give you better option. If you have Ipv 6 from your provider that may help a bit as mine only offers ipv4 with fiber.
