olivethi's avatar
olivethi
RAX200 loose internet connection
Hello friends.
I'm facing an issue with RAX200. Once a day i need to restart the router due to loosing internet connection on the extenders AX80 and also in the cable that I use direct in my PC.
Any idea of why is it happening?
FMW version:1.0.10.140
TKs in advance
  • FURRYe38's avatar
    These extenders EAX80s?
    How many extenders do you have connected?
    What is the distance between the extenders and the RAX router? In Feet.
    Does this happen with the extenders turned OFF?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What channel configurations are currently set on the router?
    • olivethi's avatar
      olivethi
      These extenders EAX80s? Yes
      I have 2 extenders
      What is the distance between the extenders and the RAX router? In Feet. 59ft
      Does this happen with the extenders turned OFF? No
      ISP Modem NOKIA Model: G-1425G-A
      What is mfr?
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Im using this CAT6
      What channel configurations are currently set on the router? 36
      What is the size of your home? Sq Ft?1,150ft
      Tks for your help.
      • FURRYe38's avatar
        For that size of home, the RAX and just 1 EAX should be enough. Can you try turning OFF one EAX80 and have the other EAX80 place about 30-40 feet away from the RAX router? See if internet connection maintains or goes down again?
