lazysusan111's avatar
lazysusan111
Follower
Nov 15, 2020
RAX200 Manual band selection while Smart Connect is turned on
Hi all,
I really like Smart Connect in theory. However there are a few devices around my home (IoT, wifi-enabled speakers, etc.) that occasionally fail to work with smart connect. I believe the router is placing them on one of the 5ghz bands despite them only being compatible with the 2.4 band.
I was surprised that the router allows you to see all of the devices connected to the network, but the only configuration you can do is selecting icons to represent them. Why not also have the option to "prefer" or "force" the device onto a specific band, even when Smart Connect is turned on? I feel like that would make Smart Connect just a little bit smarter.
  • michaelkenward's avatar
    michaelkenward
    Smart Connect won't do that. Indeed, it can't do that.
    It is down to the wifi clients (your IoT things) to pick the band. The router simply cannot tell them to use a band that they can't see.
    I'd look for some other explanation for what you see.
