gvmusic
May 05, 2020Follower
RAX200 Nighthawk AX12 - No Lan Connected while playing on my PS4, gets disconnected.
Nighthawk AX12 RAX200 is randomly causing a loss of connection.
Error: No Lan Connect
This occurs randomly, several times a week, while I am on my PS4. I lose connection and need to reboot my PS4, to stay connected for a while.
I have updated firmware, I have reset the RAX200 several times, I have verifed my Xfinity connection, and purchased my own modem (Motorola MB8600 DOCIS3.1 cable modem). I have confirmed firmware and reset this device several times.
How do I make the Nighthawk stop causing this loss of connection?
- Christian_RNETGEAR Employee Retired
Hi gvmusic,
May you provide us with the current firmware version the router is on.
Thanks,
Christian
- DefrostAspirantThis lan issue is happening to me as well.
My firmware was updated today. Ver. 1.0.2.88- BrianakabigbInitiate
Hi all,
I had the same issues with PS4 dropping completely with the RAX200 and the latest firmware. I did a downgrade to firmware 1.0.2.8 and it has worked perfectly since. I set the router to not automatically update until I know the newest version won't be terrible for the only reason I got the router. Hope it helps!
My Wifi competely drops and takes a few minutes before you can even see the wifi networks. The RAX200 has been garbage for me. Hopefully Netgear figures it out soon. After years of being a Netgear user I think it is time move on.
