Retired_Member
Aug 05, 2020RAX200 NTP Time Frozen
Anyone else have a frozen time and date in the NTP time section? Mine is frozen on Monday the 3rd at 0930 when I did the .98 FW update. I always do a paper clip reset after an update but for some reason the current time is frozen.
- dglsmcd_USMCLuminary
Will update my RAX 200 and see if I can duplicate your issue.
mine is frozen two.
- jcaxStar
This appears to be a bug introduced with the .98 firmware. Other models (including mine) affected. Some have downgraded back to previous firmware and confirmed it.
No problem here with the 98 firmware updatee-NTP functions normally-not sure what the fix is....
Ok, spoke too soon as I have now successfully broke the NTP setting with firmware 98 :smileysad: Trying to troubleshoot to see if there is a workaround fix-will update later
- psychopomp123Luminary
Yep, also getting the same issue here on V1.0.2.98_1.0.54 on my RAX200. I've noticed even using a third party NTP server (eg pool.ntp.org) no longer works on this firmware. Come on Netgear, sort this bug out!
- pb44Aspirant
I can get mine to get a correct time on reboot using time.google.com but the date and time freezes. All log entries ave same time. This is fruatrating it keeps bring my network down. Firmware V1.0.2.98_1.0.54
- CobaltikusInitiateSame here. This is why bedtimes aren't working in Circle!
- Alex_ChileInitiateExactly. My son missed his online classes because the Circle didn't allow him.
