Bustermagic's avatar
Bustermagic
RAX200 Reduction is connection speed to ISP.
Hi all,
I have a RAX200 and was on a 5000mpbs download connection with my ISP which worked fine,
I recently upgraded my ISP connection to 900mbps but the router would only connect at 500 to 600mbps on firmware version RAX200-V1.0.10.140_1.0.79.  Download speed when connected on LAN would also be reduced to 500-600mbps..  I download all of the older versions of the firmwares and found that the router can connect to my ISP at 900mbps on firmware version RAX200-V1.0.2.8_1.0.45 and download speeds are in the 800-900mbps connected on Lan.  As soon as I update the firmware to the next version RAX200_V1.0.3.106_1.0.58 the speed is restricted to 500 to 600mbps again.
Is this a known issue?  Would Netgear be willing to fix the current firmware as I lose some functionality by downgrading the firmware?
Thanks,
Dave
  • plemans's avatar
    did you try factory resetting it after the update? I'd also leave access control, traffic monitoring, and parental controls all disabled.
    • Bustermagic's avatar
      Bustermagic
      Hi,
      Yes, the router was reset to factory each time and no additional features were added.  It seems to be a firmware issue or a new feature in the firmware.
      Dave
      • plemans's avatar
        You might need to play around a little. The RAX200 hasn't had much for updates in quite a while so I doubt they'll be doing much with it. Its worthy trying to turn on/off services. Or even disabling some of the logging features that aren't needed.
