aeperkins63's avatar
Aug 22, 2023
RAX200
Just wanted to ask when looking for updates on the screen for updates and reboot, do you recommend rebooting once a month or only when it may not be operating normally??
  • FURRYe38's avatar
    When you encounter a problem, try a reboot first.
    Routers are designed to be online all the time with out any reboots. if reboots are needed all the time, there maybe a problem that needs to be vetted that reboots are covering up.
  • michaelkenward's avatar
    michaelkenward
    aeperkins63 wrote:
    ..... do you recommend rebooting once a month or only when it may not be operating normally??
    Apart from firmware updates, when the router will reboot itself, the only time I reboot a router is when the mains power goes off and comes back on.
    Other than that, leave it alone.
    • plemans's avatar
      I'm the same. Leave it 24/7 unless the power dies or I have an issue with something.
