EcoDieselDave
Aug 24, 2019Guide
Rax40 setup & access
Can anyone help, messaged Netgear no replies in days, new RAX40 however after Basic set up only changing network names to what I had Prior on my TP-link so I wouldn't need to redo all my TV's or Smart Hub Samsung smart thing's & Ring Cameras & ring Flood cameras.
Using the IP on laptop to access setup or the android nighthawk app everything takes forever to load, even to access the router in the same room tasks minutes, can't run a speed test even or make a change the app or computer just thinks & spins & takes forever.
My old Tp-link archer ac1900 took moments to load make changes, reboot just like everything these days.
Is there some security or something that's causing this retardation I need to set it & forget it. Whole reason a spent a couple hundred is my old router is 5 years old & 8-year-old tech. I simply wanted a router which would push the same speed coming in out on the 2.4 network, my speed is minimum 400 download & 20upload. In my case I only care about upload speed hence the new Router
Sure hope someone can mention some help as Netgear isn't any help
Sort By
- Ctanner589AspirantHey. I was having the EXACT same problem after "upgrading" to the RAX40. Log into your router using an internet browser, click on the Advanced tab, select setup, and then wireless setup. If the box for Enable AX is selected, try to unselect it (disable Ax and OFDMA). Not sure why, but having this enabled made my network go crazy. Maybe because it is something newer? I'm not sure.
- Thank you for this!
I actually wasted a half a day on this Saturday making the mistake of calling in, total of 3+ hours 1 call 5 transfers & 3 techs, & Not a one in the USA & All verifying my info 7 times total, Netgear actually stated the Rax 40 has an issue across the board. They emailed me a link to change firmware & again stated only the Rax 40 had this issue. Not the Rax80 or others.
Not sure if this is fixed it but I greatly appreciate your response. I lost 2x the amount in income this rax40 cost. So If I return it in out $600.
I just need a router that works.
I'll try this also, though I don't know these acronyms or language
I just can't understand why a 10-year-old TP-link the app access is instant, but this Rax40 takes minutes to just connect? Minutes to make changes. Minutes to do it's own speedtest even??
Thank you again- Christian_RNETGEAR Employee Retired
EcoDieselDave,
Would you mind sending me a message with your case number and email address. I'd like to have your support case escalated.
~Christian
