Mims455
Jan 05, 2022Aspirant
RAX40 v2 DHCP Option
Hello,
I just bought the NightHawk RAX40 v2 routeur in order to replace my provider one. To do that, i need the DHCP option 60 and 61. As precised by the following KB article https://kb.netgear.com/000062426/Which-NETGEAR-routers-support-DHCP-option-60-and-61, it should be supported, but it is not. I guess it is only for the RAX40 v1 (but it is not precised in the KB...)
Is there any chance to add this feature for the RAX40 v2 ?
Thanks
The original RAX40 was an intel based device.
The RAX40v2 is a broadcom based (per fcc).
Whether that'll get the update is an unknown.
It is a bit sketchy that it doesn't list in the "supported devices" that its only V1 supported.
Any idea if this is a planned feature? DarrenM
Something to contact NG support about and see though maybe something that could take a while, even if they might support it:
https://my.netgear.com/support/contact.aspx
You might get something on that list the does fully support that if you need it.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
