jmorgie7
Apr 21, 2021Aspirant
RAX43 dropping IoT hub
New router, installed <7 days. I have 40-45 devices total on the router; 6 Windows, 4 Android phones, 3 android tablets, 4 internet TV, many light bulbs, switches, plugs etc. One specific device is a hub that translates between Wifi and Bluetooth for a door latch [Lockly]. the hub works when freshly installed but after a day or two attempts to interact with the latch from the android app get a message that 'connection failed, try again'. support at Lockly say the message means that the Wifi comm is not working -- different message if the blue tooth link were not working. The hub itself displays steady Green light so the hub thinks it has communicaiton with the router. the Hub is located within 10ft of the router [directly below on a different floor]. Even accounting for losses due to walls, flooring etc this is NOT a signal strength issue. Measuring signal strength with an app shows very strong wifi signal. and, oh yes, ping succeeds in getting a response from the hub.
SO: the Nighthawk is not giving the hub the timely service when the hub needs.
1. Why is communication dropping ?
2. Can I set a higher priority to the Hub ?
- Christian_RNETGEAR Employee Retired
Hello jmorgie7,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- jmorgie7Aspirant
Yes it is new. I have wasted > 1 hour trying to contact Netgear support ... they tell me to try the community.
So have you any insight into this problem ? instead of just shining me on ....
Hello jmorgie7,
May you send me a private message with your email address and case number(s). I'd like to look into this further for you.
Regards,Christian
