Alpinebs
Mar 20, 2022Tutor
RAX43 dropping WAN from 1G/1G to 500Mb/80Mb
Im curious if there has been any resolution to the reduction of available bandwidth on netgear routers. Using an RAX43 AX4200 on a balanced gig fiber connection and as every other thread ive read, it measures 925/950ish on multiple test sites for seeming up to an hours after reboot then drops to a predictable 450-600/80. This all hardwired to the router. I have tried:
Default
No QOS
no bitdefender
no parental controls
new patch cable
and a miriad of other suggested controls and just like every thread on here it ends with ...
Is there a resolve to this? Am i just screwed in using a netgear product? Of course its 4 mo old and i just swtiched from a 350/10 connection where i never noticed any sort of reduction, so now there is no support and past return period.
Thanks!
- microchip8Master
I don't have a symmetric 1Gbps/1Gbps connection, but I had no problems hitting 1 Gbps download even after 2 weeks of operations on my RAX43. My upload is only 50 Mbps so I can't test that.
Which firmware version are you using? (not "the latest", a number)
What modem are you using?
- AlpinebsTutor
microchip8 , the latest firmware
JK, V1.0.10.110_2.0.75
its a fiber connection so no modem. Gigpoint 803G media converter.
- microchip8Master
I have the same FW as you and no issues here. Do you have traffic meter enabled?
Also, what modem/ONT is in front of the RAX43?
You can try factory reset and reconfigure from scratch (don't use a saved settings file. It defeats the purpose of factory reset)
- Guru1911AspirantCheck your mtu settings
