j-d-m
Jul 02, 2020Tutor
RAX45 Firmware Error (GUI language table)
I'm unable to update from 1.0.2.20 to 1.0.2.28 because of an invalid GUI language table. I waited a few days to see if it was a server issue but still getting the same error. Is anyone else having this issue?
Yes have been currently having the same issue. I attempted multiple times with different devices as well as direct with router login with no success. Last thing that remains is to reset to stock and attempt to update that way but afraid it might cause more harm than good as per previous posts.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Found this, may help to update manually- j-d-mTutor
Thanks for the link. I'm also glad to know it isn't just me. Hopefully Netgear engineers can get on fixing this.
- SCharlieInitiate
I am having the same issue with the language file.
I had the problem with 28 and now 32 updates.
I did this firmware update manually but I would really like it to work through through Safari, Chrome browsers.
This needs to be fixed so we can update easier.
