dmjeziorski
Apr 06, 2022Aspirant
RAX45 Guest Network doesnt connect to internet
Netgear AX4300 RAX45 (Costco version) configured for 2.4GHz guest network will not connect to the internet. This was working and I am not sure when it quit. Other networks are working just fine. The 5GHz guest network is off. Firmware is V1.0.2.82_2.0.50. There is an update available but I have not yet installed. I am using SurfBoard SB8200 modem. I have disabled/enabled the guest network but still NG. Checking the forum other posts are pretty old and none address this router. Help please if you can.
Sorry for the misleading model. I did not find this one in the predefined listings.
DaveJ
- dmjeziorskiAspirant
The firmware is the version it came with and was running with the initial setup was done. Nothng was changed since.
DaveJ
You may want to update fw to this:
Or I see NG put out v.110:
See if this clears up the GN issue...
