jodyhama's avatar
jodyhama
Follower
Aug 23, 2020
RAX45 Nighthawk Router, 802.11ax does not work with Windows10 Laptop
I just purchased a Nighthawk Router with WiFi 6 (AX) at Costco.  I got everything set up, except when I tried to set up my Dell laptop with Windows 10.  The SSID name did not show up, we tried many things, and finally disabled the ax feature in the admin setup.  The SSID finally showed up.  Is there some kind of incompatibility with Windows 10 or Dell laptops?  I was able to set up my Surface Laptop, but I still don't think I am getting the full capability of the Router.  Is the ax feature only for New equipment?  Is there a patch or something to make it work?  My computers are about 3 years old.
  • schumaku's avatar
    schumaku
    Updating the Wi-Fi adapter drivers often fix such issues. Integrators like Dell are often more than lazy with making driver updates available.
  • I purchased a new  Lenovo P15s  laptop which was supposed to be able to use 802.11ax.
    I have the 802.11ax SSID enabled on my router.
    I have updated the Lenovo Intel network ax driver to latest version.
    I have installed inSSIDer software.
    I cannot see the SSID as a choice on my laptop as a network to join.
    I dont see the AX on inSSIDer software either.
    I dont know if the router is not working or if the laptop driver can just not see it.
    There are many settings on the laptop network driver - so it may be a setting.
    Any ideas would be appreciated.
    • Dan32's avatar
      Dan32
      Apprentice
      Intel just released a major wireless/BT driver update that fixes a long list of issues.
      If you don't have version 21.120.2.1, best to give that a try and see if it helps at all.  If you're not sure how to figure out what version you have, go to Intel and install and run their support assistant.  It will tell you if you need an update.  Windows 10 updates, including updating via Driver Manager, may not get you the latest drivers.  (That includes Dell's Update version of the same)
