frankie6737
Aug 23, 2020Aspirant
RAX45 VPN not working
Activated VPN service but cannot connect to router via VPN. Checking log and found that
[OPENVPN] NTP sync time failed. Get correct system time then reconnect. Sunday, Aug 23,2020 08:40:44
tried to change different NTP server but still didn't work
- Christian_RNETGEAR Employee Retired
Hi frank6737,
Were you able to get this sorted out? What firmware version is your router currently on?
Christian
- frankie6737Aspirant
Tried both 1.0.2.28 and 1.0.2.66(latest update) but still didn't work. Same log found
Hi frank6737,
Thanks for confirming. Have you had a moment to get in contact with our support team regarding this?
https://www.netgear.com/support/default.aspx
Christian
