xgourmet
Jan 19, 2022Guide
RAX48 Firmware Update - GUI language file is invalid
I tried to update the firmware of my RAX48 router and get the following error: GUI language file is invalid
Firmware Update Assistant | |
| New firmware is found. Do you want to update the firmware? (Yes) (No) | |
| Current GUI Language Version: | 1.0.2.82_2.1.46.1 |
| New GUI Language Version: | 1.0.5.106_2.1.46.1 |
| Current Firmware Version | 1.0.2.82 |
| New Firmware Version | 1.0.5.106 |
Any ideas how to resolve this?
have you tried manually updating?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- xgourmetGuide
Unfortunately the firewall on my company issued laptop prevents me from downloading the file from
https://www.downloads.netgear.com/files/GDC/RAX48/RAX48-V1.0.5.106_2.0.70.zip
doesn't the automatic updater download the same file? are there any other options?
- plemansGuru - Experienced UserTry on a non work computer
- bigrayAspirantI have the same issue. Can’t automatically or manually update. Now router not working
