A5W4eXCNhzArsec
Oct 27, 2021Aspirant
RAX48 wifi channel changed
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/RAX48-wifi-channel-changed/m-p/2156255
I set the 5GHz channel to 36. After a month, I scan nearby wifi and found out my wifi is on channel 149.
I logged in to my router and it is still showing 5GHz on channel 36.
Can you explain what's happened? 149 is a congested channel in my area.
Sort By
What are you using for wifi scanning?
Got a screen snip?
What do the actual devices connected to it show when you pull up their wifi specifics?
- A5W4eXCNhzArsecAspirant
I am using macbook wireless diagnostics to scan wifi.
The wifi channel shows channel 149 when macbook connects to the 5GHz wifi.
